deuce winch question ??
CanadaDeuce
Nelson, BC, Canada
How much and what size of cable is on a Deuce front winch drum ?, also where the hook and chain lead attaches to the cable is this a special MV piece ? also any special clamps to attach to the drum ? :eek:
anyone have any hooks and chain leads ? used or NOS ? if so pls contact off line by PM
CanadaDeuce
1,824
The termination at the end of the cable is made by http://www.esmet.com/
It is the Electroline series. I had an NOS one but recently gave it up for a friend in need. Dunno what they cost new.
sermis
17
Temple, TX
RE: chain leads
I have wire rope $150 + ride for 220' I think I have a leader chain $50. I will need to check the chain size.
emmado22
166
Mid Hudson Valley NY
The fiber core is for lubricating the wire. When any wire rope cable breaks under load, it's a bad deal no matter what the middle of the cable is made out of.
gimpyrobb
dumpsterlandingfromorbit!
27,787
777
Cincy Ohio
So it acts like a wick to hold the lube? Thats pretty cool.
emmado22
166
Correct. One note.. When you insert the brass "conical wedge" on the clevis, you need to cut the fiber core strand out or the wedge wont seat correctly.
FOLLOW THESE DIRECTIONS....
http://www.steelsoldiers.com/index.php?module=pagesetter&func=viewpub&tid=3&pid=72
I did find it much easier to leave like 4-5 inches of strands above the point where I cut the core, and beat it in, then just trim the excess off the top, leaving it exactly was they say.
