Deunce Winshields
rmgill
14
Decatur, Ga
So I bought a pair of the Korean made windshields at the GaMVPA rally from Kevin Emdee/Star Electric Ordnance. I installed one the other day at the event and got the other installed today. I tweaked the first one to get it done right and once adjusted, they seal MUCH better than the standard US made Windshields. The rubber seals around the edges are continuous in a 'U' shape and the tops have a set of rubber foam seals at the corners to aid sealing of the upper hinge strip.
When closing them you DO have to check to see if the windshield is centered but you can easily do this when closing the window.
rmgill
14
Decatur, Ga
Oh, one problem. Does anyone have a spare windshield wiper arm brass nut? I managed to drop one of the ones I had and it bounced off the fender into the grass and naturally cannot find it. :roll:
jimm1009
70
Louisville, KY
pic as requested
Well o.k., but only because you asked.
:twisted: :-D
Hope this was the correct pic since I had none of the seal itself.
:twisted:
jimm1009
Seriously though, my windshields were both burned by welding on the cowl area by Uncle Sam and they were not protected so if part numbers and vendors come available it would be nice.
I'll gently blast and repaint mine just for G.P.
jimm1009
70
Louisville, KY
They look plenty "installed" to me! :twisted: Ur, I mean yes can we see the glass installed? :roll:
I would like to replace my glass too since both of them have imbedded steel and that is a little rought on wiper blades.
jimm1009
Jimma
Hartwell, GA
My passenger side windshield has the rubber trim / gaskets but has about a 1/4th inch space open at the bottom letting in a lot of rain. How can you adjust them?
The Gimlis
Minden, NV
After we got caught in a rain storm and got drenched, the Mr. decided to get rid of the stock windshields. Our local glass shop - who like the rest of us doesn't have a lot going on - jumped at the chance to make us a one-piece. It increases your visibility and you have no worries about leaking - if your glass guy is good, that is. Cost us around $250 installed.
It's a cool idea for those of you looking to customize. While you are at it, change to electric windshield wipers!
---- (Those are very interesting pictures of "windshields", too. A different definition of "visibility"...)
Here's our windshield.
Love you guys!
