Dex/merc atf fluid
twisted60
241
Jupiter, Florida
Use Dextron 3, find a copy of the Quick Reference guide for HMMWV, Lube order and read the -10 all good sources of info. The TM's are your friend, all the info can be found in there, but if you're stuck ask, we've all been there once or twice.
Dextron 3 in Transmission, transfer case and power steering.
Below comment out of HMMWV Quick Ref Guide Third Edition
COMMENTS:
A. Dexron III is the new version of Dexron II. You will derive several benefits from using Dexron III in your transmission:
