- 26,247
- 1,171
- 113
- NY
I recently won(GL) an M817. Towed it home with the M819.
When I brought it home, I found the motor was "locked up".
I don't see any oil or coolant contamination. When I drained the oil, I found no metallic parts or anything on the drain plug magnet.
I removed the valve covers and noticed the exhaust valve adjustment lock nut on cyl #3 was MIA.The adjuster was unscrewed to the point that the rocker arm was touching the valve(bridge). I cleaned the threads with a tap and reinstalled the adjuster with a locknut. I also noticed when I tapped on the valve, it stuck in. Bent, I assume.
I pulled the inspection cover on the block. Saw cyl #4 journal, and it looked good. That's about all I could see in that window. What is this window for?
