Looks like my temp gauge is grossly inaccurate.
I installed a cheap-o Summit Racing mechanical gauge along side of the factory sending unit, and wedged it in the dash between the front axle switch and the heater controls.
The OE unit is reading 200 degrees, while the Summit one reads around 160.
I installed a new thermostat just as a safe measure, but really dont think it would have made a difference, once I opened the box and looked at the new thermostat. It look like a "coolant resistor". I really don't see how, mechanically, this thing would or could open and close.
In the process of looking at the wiring for the temp gauge, I managed to short out the entire electrical system, melting what looks to be a fusible link between the main wiring harness and the alternator, right at the alternator itself...No start, no fuel pump, no gauges, no nothing.
Figured that out and now the deuce is outside idling, I'll post back up when I return from hauling water to say "yea" or "nay" on my overtemp diagnosis.
Thanks to SteelSoldiers for once again, saving the day with wiring diagrams, and other information.
