- 1,579
- 540
- 113
- Greenback, TN
I went by the local Allison representative today to make an appointment to bring my LMTV in for diagnostics on the transmission. He showed me the connectors on his test box so I could locate the matching socket on the LMTV. I do not find a port that matches.
What I found is this (photo) and it's about 20 pins larger than his test box.
He mentioned WTEC II and III associated with the test box, but this connector doesn't match either. A search on SS yielded comments about early transmissions with analog test points.
This LMTV may be 'early' version, dated 1994. Did things change any time after that? What diagnostics do I have and how do I use this port?
This transmission works fine but it seems to need the engine to be wound out to max before it shifts. Is that normal? Sure will be hard on fuel this way. I'd like to have it shift at a much lower rpm.
thanks.
thanks.
