- 6,863
- 707
- 113
- Stratford/Connecticut
Thanks. I will check that air solenoid in the morning. When the fan works I do hear that air get dumped, and when the fan does not come on there is no air dump. I had assumed the problem was electrical.You might carefully check the air solenoid that controls the fan. It dumps air to engage the fan. Mine appeared to work fine on the bench but when put under load in the truck it failed to vent the air between it and the fan clutch.
It was very intermittent in the beginning. There was no predicting how it would react.
The solenoid is located behind the passenger kick panel just inside the door. With the kick panel off you can hear the distinctive air dump sound when the solenoid engages. The solenoid is normally engaged to keep the fan clutch off and disengages when temp is high. This arrangement makes it fail safe should a wire break or such.
Seems as though it has been a problem for a lot of LMTV owners
