Diesel Mechanic Houston area
3dubs
Houston, TX
I am trying to see if there is someone on here that gets shop rates at M&D. I am not asking for prices to be posted just PM me. I need to get my IP rebuilt but the price I get is almost twice what I can get it for if I ship it out. I would prefer to have to done local but I only have my disability check from the VA.
3dubs
Houston, TX
Diesel fuel is leaking out of it.
I had to rebuild the engine when I got it and replaced the IP because I was told it did not work. So I have a leaking IP on the truck and one I was told did not work in the garage. I called and a bench test cost too much. So I am going to bolt the original back on and see if it works. Even if it does work I would like to have an IP on hand. Just my luck it will go out when I am broke. The leaking one I will replace the O rings on the throttle shaft myself. This is what I drive everyday and I have to make sure I keep it running.
