diesel noises
digitaldust
Twp Flint ,Mi ,
how would one know if a white diesel had a rod going ? how does the know play out what kind of knock would it be
gears are they straight cut ? should i be hearing a light wow wow wow syncro sound?
hissing from the dash is this normal fix going on here ?
i build pressure for air 0 - 100 lbs in like 1 -1.5 min
m109a3 with 16,500 miles and 572 hrs clean truck
thanks I'm into day 3 now by a few hrs
WillWagner
2,732
Monrovia, Ca.
If you are concerned about the internal workings, easiest thing to do is cut the oil filtres open to see if there are "sparkleys" in the media.
Stretch44875
Super Jr. Moderator
30
Tiro, Ohio
It's pretty easy to pull the pan, and check for loose rod/main bearings. Jack up the frame of the truck some, letting the axle drop, to gain enough room to remove the pan.
digitaldust
Twp Flint ,Mi ,
i dont here knocking a low rpm but at 2100 ir so or in 5th at 2000 2200 there is a clattering sound ,, what should oil pressure be its stright to 30 at start then to 60 after rpm hits 1000
Maverick1701
181
Lubbock, TX
I hope so...mine does the same thing.
I think the info is in the TMs somewhere but I can never remember what the TMs say when I am driving in the truck
