Diesel pump transfer unit specs..?
islandguydon
783
Michigan
I have already searched the TM's and searched HI & lo for the Tm for operating this pump unit. Can a guy get a little help please..?
EDIT:
I found the TM for this Fuel Pump Station. THe TM is: TM 10 4930-236-13&P
This is found half way down the PDF attached.
1,172
The unit should have a data plate on it that tell you what TM is needed.
Then a google search of that number should find it.
Ferroequinologist
Resident railroad expert
736
Liberty Hill, SC
I don't have the TM. I usually work off the 'I know what this part, this part, and this part do separately, so if I do this or that then the output should be this' method. Hasn't blown up or killed me... YET.
I have disassembled mine, as I plan to modify it and mount it with a pod on what's left of my MKT for a mobile fueling system.
6x6TRex
Flint, MI
I have the TMs for it, I'll post them up later tonight or tomorrow.
Edit: Don, do you know you already asked this question 4 months ago? :p
http://www.steelsoldiers.com/auxiliary-equipment/88049-fuel-station-pump-filter-question.html
I'll double check later to make sure but look for 4930-236-13&P for the pump system and beta tanks. TM 10-4330-232-12&P is suppose to have the parts breakdown for the filter.
Where I got the TMs from: http://www.steelsoldiers.com/auxiliary-equipment/84501-tm-beta-systems-500gal-tank-needed.html
islandguydon
783
Michigan
I have the TM's for it, I'll post them up later tonight or tomorrow.
Where I got the TM's from: http://www.steelsoldiers.com/auxiliary-equipment/84501-tm-beta-systems-500gal-tank-needed.html
6x6Trex and Ferro thanks..!
I got it a few months ago, My old computer fried, hence lost all the data, here is what the data plate says. Thanks for the help. I am mounting this pump in the back of an A3 with a 308 gallon transfer tank. I am going to use it for picking up ATF / UMO and mineral oil. Does anyone think I will have a problem with the suction with anything other than diesel..? I think the pump should be OK for a little bit heavier fluid. What do you think..?
