Differences between 6.5 GEP NA and turbo
alpine44
Asheville, NC - Elkton, MD
What are the differences between the 6.5L GEP NA and 6.5L GEP Turbo (other than the obvious addition of a turbo charger)?
Is the angle of the intake headers the same and can the turbo with manifold be added to a 6.5L GEP NA engine?
NDT
5,918
Camp Wood/LC, TX
The turbo engine has the different heads that are used with GM vans and H1/HMMWV.
If you are looking for an engine for a CUCV and wish to install a GM truck side mount turbocharger, get the NA GEP engine. The HMMWV turbocharged engine will not fit in a CUCV or CUCVII due to the exhaust pipes being routed along the back of the engine, where they will hit the firewall.
alpine44
This is NOT for a CUCV but for a M998. Rear mount turbo is what I need. Just wondering whether the turbo plus intake header from the turbo engine will fit the NA block. Again, this question pertains to the GEP blocks.
gringeltaube
Staff Member
2,279
Montevideo/Uruguay
Can they be drilled, tapped, or faced without taking the whole thing apart?
The answer is no.
That kind of work needs to be done with a milling machine, and you better do this after the block was completely stripped, since there will be iron chips and -dust, everywhere and especially inside the oil gallery!
As NDT has indicated your #10163726 (N/A)heads will have to be replaced with the #12556822 (turbo)heads in order to accept the turbo-model, specific intake manifolds.
G.
alpine44
Thanks all for the helpful info.
If I understand it correctly:
  • The M998 would require a 6.5L GEP Turbo engine plus modifications to body, doghouse, and exhaust.
  • The 6.5L GEP NA block would be a better candidate for a side turbo setup in a CUCV (with a custom oil feed and return for the turbo).
  • Both blocks should alleviate worries about the dreaded cracks at the main bearings.
Retiredwarhorses
3,893
Brentwood, Calif
the issue was #8 cyl crack issue on early turbos....amongst others, but that was the #1 fix when GEP took it over.
GM didn't want to bother due to the soon to be released Duramax....no sense in dumping money on an old design.
