Banshee365
- 14
- 0
- Ocala, FL
Okay, I admit it. I used a bit too much force on my compressor pulley and broke one of the ears on the split off on the front part of my compressor pulley. So I ordered a new one off ebay. I tried to get the old one apart but it still wouldn't budge. Waited a couple weeks for it to come in and it finally did, I was excited. Went out to the truck installed it, slipped the belt on and the thing stuck so much farther out than the original that the belts rubbed. That wasn't going to work. I noticed the back of the pulley was alot thicker than the one I had originally. So I knew I had to either order another one and waste more money or get that dang old one apart so I could use the back of it and the front of the new one since they're the same. After lot's of hammering a chisel between the split's, lot's of pentitrant, and lot's of heat i finally got it apart. I just thought I would post the differances in case anyone needs to replace there pulley. I'm guessing the difference is from 1 and 2 cylinder compressors. What do yall think?
-Kelly
-Kelly
