1984CUCV
- 0
- 0
- tampa florida
is it just my truck or do CUCV directional light indicators in the cab not work? Mine has never worked but it got me to thinking is it just my truck or are all like that? Thanks!!!!
No, the signal ALWAYS works, it's just when you make a turn the signal should cancel itself out after completing the turn.Replace the signal flasher. That 'kinda works when not' vs 'works fine when cold' is definitely an electrical problem, probably related directly to the flasher.
BUT I'd also check all the bulbs in the right side flasher circuit and clean all the connections, including the light under the dash.
