You may be right, but it's always nice to have options. I for one would much rather clean disks than drumsi am not sure what you gain with disk brakes on a truck like this. the shortcomings in braking are not so much the drum brakes, but the booster and the low pressure it generates. my re-engineered brake systems have all had stock brakes at the wheels, but you can lock them easily with one finger on the brake pedal. the other half of the brake system needs to be done first, and then i doubt anyone would want disk.
tom
yep - totally forgot that the caliper brackets were machined. it was done quite nicely, so much so that it is easy to miss!View attachment 265982
Ask and you shall receive. factory is straight with no radius. ill post a pic of a factory one when i get home. Kyle
reliability, essentially zero maintenance, life span, braking performance (w/ 1600's).i am not sure what you gain with disk brakes on a truck like this. ...
I don't think so. I think they need a separate thread for that. There is a thread linked in the first post for that type of discussion.Guys,
I don't drive on the highway. The stock brake system works fine for the low speed off road driving I do, so this thread does not apply to my needs. However I do dream a lot! In my opinion this thread should be expanded to incorporate power steering and the hydro-boost brake master cylinder.
These improvements are a package! Please continue the good discussion and collection of information, but please include the booster, pump, and steering component part identification that make the upgrade complete.
BTW, it will be good to include prices of ALL the parts, as you did on the first rotors you identified.
Thanks all,
Rick
The 1999 up f350 caliper is made to fit a 13" rotor not a 15" rotor, i do use this caliper on the 15" rotor but the frame of the caliper is modified to fit. As for the bottom bracket, the most important thing is that the weight of truck is pushing down on the bottom king pin and A36 steel will not last long. This area must be case hardened. Next week i will make a batch of brackets and can post pic's on this process.Just some food for thought. Using the f350 calipers on the front instead of using the f550 makes the brackets longer and has more bend in the bottom bracket. If you notice on steves brackets the huge gusset he has support the bottom bracket after being bent. Also, think this was covered but you need to grind the saddle quit a bit on the caliper on the f550. Just info for the at home builder.
also the part number i always used for the rotors is RAYBESTOS Part # 8520.
What made you make this decision ? Did bracket fail at one point? Or show signs of fatigue. What are the original king pin caps made of? Thanks KyleThe 1999 up f350 caliper is made to fit a 13" rotor not a 15" rotor, i do use this caliper on the 15" rotor but the frame of the caliper is modified to fit. As for the bottom bracket, the most important thing is that the weight of truck is pushing down on the bottom king pin and A36 steel will not last long. This area must be case hardened. Next week i will make a batch of brackets and can post pic's on this process.
I do not understand the question.What made you make this decision ? Did bracket fail at one point? Or show signs of fatigue. What are the original king pin caps made of? Thanks Kyle
What made you decided to case harded the lower brackets. KyleI do not understand the question.
The very first disk brake brackets ( kits) i made 11 years ago up to today are the same. To the statments i made on case hard is for the people who copy my brake setup do not case hard their bottom bracket. The bottom cap is about 55 rockwell scale C, the case hard i do is 60 to 64, the same as atimken bearing race. Case hard pic's, to the rockwell bottom caps worn half way through.What made you make this decision ? Did bracket fail at one point? Or show signs of fatigue. What are the original king pin caps made of? Thanks Kyle
I'm not quite sure what I'm looking at in the last pic ? Could you explain a bit more ?The very first disk brake brackets ( kits) i made 11 years ago up to today are the same. To the statments i made on case hard is for the people who copy my brake setup do not case hard their bottom bracket. The bottom cap is about 55 rockwell scale C, the case hard i do is 60 to 64, the same as atimken bearing race. Case hard pic's, to the rockwell bottom caps worn half way through.
I should have done it step by step. First pic with a rose bud to 1,600 degress and then put the hardening powder on the hot spot. It welts into steel about 1/16 of an inch and place in cool water at about 1,100 degress. The pic of the bracket is after it came out of the bucket of water case hardened. The 3 caps, one is used very little and the other 2 were used long term with no grease. I have seen a complete hole through the cap and the king pin hanging out the bottom.I'm not quite sure what I'm looking at in the last pic ? Could you explain a bit more ?
