JasonS
- 144
- 63
- Eastern SD
I have found that most (at least all that I have encountered) injector issues are due to the pintle being stuck/ sticky. Freeing it up and cleaning it up has been sufficient to put it back in service. There are low cost injector pop testers on Amazon for less than $100 which work fine. My pop tester came with two injection line tubes. I adapted one to my Onan injector and the other to the multifuel injector:
The injector sleeve/ferrules are available from a variety of sources. I got mine here: https://www.tractorpartsasap.com/sleeve-injection-pipe-new-international-162718.html The nut is simply an inverted brake line fitting from Napa (Balkamp 641-3324).
