WhoMe08721
- 124
- 43
- Bayville/NJ
Spindle nuts ?Can I request you put them on first and test for us? Otherwise we might not know if it’s them or spindle nuts that fixed the issue![]()
Understood, but my point being when chasing vibes it’s important to only make one change at a time.Spindle nuts ?
If those are loose....they will come off after the lock tab brakes off....then ...there goes that tire/wheel/axle.
Yep sure will. Could be a ujoint/halffshaft ect also.Can I request you put them on first and test for us? Otherwise we might not know if it’s them or spindle nuts that fixed the issue![]()
Your wheel was probably shaking at 75mph, because you were going too fast....Had them on the m998 sense Saturday and so far they are working out great. They don't give off any sounds and I been doing 65mph every day and no shakes in the steering wheel. But the main reason for putting them on was when I am doing 75mph ish the steering wheel had a little shakes that I could have live with. But then I came across these and I though I would give them a try. So far I would recommend them, but I need to do more highway test with them. Plan on doing a lot of highway driving later this week will get back to you guys how they hold up.
Also dose any one know if they make a set for the deuce and a half.
The business started with semitruck fleet product. They should...Had them on the m998 sense Saturday and so far they are working out great. They don't give off any sounds and I been doing 65mph every day and no shakes in the steering wheel. But the main reason for putting them on was when I am doing 75mph ish the steering wheel had a little shakes that I could have live with. But then I came across these and I though I would give them a try. So far I would recommend them, but I need to do more highway test with them. Plan on doing a lot of highway driving later this week will get back to you guys how they hold up.
Im no scientist, but when the wheel needs more lead than the balancer can compensate for, you still have an out of balance tire / wheel. I did stay at a holiday inn once.They expressly warned against balancing the wheel and tire conventionally and said this will only work against the cerramatic when I called them.
The question is, how much of an unbalance can their Hummer/H1 model actually compensate? Nowhere in their brochures could I find any specifics.Im no scientist, but when the wheel needs more lead than the balancer can compensate for, you still have an out of balance tire / wheel...
There is absolutely no logic in that. Within limits, their product should be able to compensate ANY unbalance condition, including a perfectly balanced assembly!They expressly warned against balancing the wheel and tire conventionally and said this will only work against the cerramatic when I called them.
More likely the prototype for his truck were made the best they could be , then it went into production with materials that were good enough to keep costs down and profit up.Just reporting what the company told me. My balance situation was that one wheel was calling for 17oz at the local tire shop spin balancer. Centramatic said their balancer is rated for up to 12oz of compensation, if I remember right. But the tech person said, try them and see, they will surprise you what they can balance.
Also just as an FYI the reason they make a hmmwv specific balancer is the owner of the company owned an h1. So you can be sure they were made the best they can be for our application!
