DN4M/LPW4/MEP-803A Gen Set
vjogitte
Tamarac, FL
Hi guys! I just joined the site looking for some help with this gen set MEP-803A I purchased on the GovPlanet auction. After purchasing it as a nonoperational check item I brought it home add new oil and filter and 2 new batteries when I tried to crank it the stator turns with a grinding sound but not the engine, I tried to turn the engine manually at the crank pulley bolt it wouldn't turn, come to realize there was a small crack on the engine block, seems like it threw a rod and the crankshaft split which is why the stator turns when I tried to start it.
Any idea where I can get a replacement engine? or please if anyone has a parts engine laying around please let me know. Thanks
Ray70
5,820
West greenwich/RI
Welcome to he site, you will find a lot of great help here. Unfortunately a spare running DN4M will be somewhat scarce, might be easier to locate a cheap MEP-813 ( 400 hz. generator ) and take the motor out of that, since it is identical.
Also, you should correct the title of your thread to 803 , not 808 as some folks will pass right by thinking you have some gigantic power plant, not a 4 cyl. 10K.
vjogitte
Tamarac, FL
Thanks for the info on the 813 I will check on that and also thanks for the correction I didn't realize I had the typo.
jmenende
389
Puerto Rico
I bought a running 803 on govplanet last month. Guys here on Steelsoldiers were a big help in getting in operating in tip top shape. I love the idea of getting an engine from a 400hz unit. Good luck.
I actually just received my 813a today. Bought it to to replace a seized 803a. Spare parts is what these 400hz units are good for. You can use the genhead as a good boat anchor. Let the fun begin.
vjogitte
Tamarac, FL
I might have access to a locked up 4 cylinder engine. I have not evaluated it, but I know where one is if you were interested.
Sorry for the late reply, but sure I like to check it out, hopefully it's something I can turn the crank and put a new set of bearing in, please let me know.
Ray70
5,820
West greenwich/RI
Just an FYI, 99% of the time the reason the LPW4's get stuck is due to water in the cylinders ( down the exhaust )
causing the pistons to get stuck.
Many times you can free them up, hone the cylinders ( replace rings if necessary ) and be good to go.
A couple times I have had to go .010" over and get oversized pistons, which are readily available fairly cheap online.
Pretty easy to totally rebuild these motors if necessary, and parts are pretty easy to find, you just need to know how to look to get the best prices. ( search by engine name, not generator model )
vjogitte
Tamarac, FL
In my case I think the crankshaft split, I haven’t taken it apart yet but I noticed a little crack on one side of the block indicating a damaged rod. I also search under DN4M and LPW4
Light in the Dark
5,882
MA
Search LISTER PETTER ONAN DN4 DIESEL ENGINE on eBay. You will see a group called Adelmans has (2) nonturning engines in stock. This company does not have an excelent reputation, but its a start.
