- 1,841
- 1,172
- 113
- Ostrander, Ohio
I got a couple of frame sections to extend the front bumper. I'm eventually going to put on an electric winch (too much cost and work to add a OEM winch to a WO/W). I have 14" sections to put on, and I bought some 1/4" plate to splice the extensions on. I have 2X18" wide pieces for the top and bottom of the frame channel, and 6X18" plates for the side. For some reason I thought the frame was 1/4" (I know, measure twice.....). It's 1018 steel (American, of course!)
I'm going to use the original bolts and new grade 8 bolts to splice the sections using the original bolt hole pattern. Will this be strong enough, or do you think I should add a second 1/4" plate on the sides?? Opinions??
