Do these 2.5 tons have sealed brake drums ?
Al Capone
Pearl river la
I don't own one of these but did many years ago . I don't remember if they had sealed brake drums . Our local town has one of these with the large single tires. They were using it in flood waters last week . I told them they need to check all fluids . And was wondering if they had sealed drums if so they need to check them for leakage . Also it might be 5 ton . Have not stopped and looked at it . Thanks . Al
gimpyrobb
dumpsterlandingfromorbit!
27,785
749
Cincy Ohio
No, deuce OR 5ton, you need to go through the axles and drain, refill the trans and T-case. Might not be a bad idea to do the motor oil too.
gimpyrobb
27,785
749
Cincy Ohio
Yeah, if they don't pull the brakes, all that grit will tear up the brake pads and render them useless quickly.
