Dodge 230 Broken Piston
Texjun
Dish Texas
I was just going to change Oil Pan Gasket, but they I found two broken pieces of Piston #6.
Only #6 has failed all other piston shirts and tops look good.
Has anyone ever seen a piston failure where the skirt broke off in two pieces and piston above the broken shirt started to cave in.
Overhaul Data-plate says pistons were standard at Rebuild back in 1972.
I took a quick measurement of the cylinder #6 with my caliper and got 3.248, there is no step wear at top of any of the cylinders.
Anyone have any take out Standard Pistons they could share I only need one?
Still looking, one of the great guys on SS send me one, but Unfortuneally it was not a Standard I need one good used STANDARD PISTON.
# 6 Piston Broken.jpg# 6 Piston metal in oil pan.jpg# 6 Cylinder no step.jpg
Bill W
Brooks,Ga
This was the #6 piston that came out of my parts (V-41 ) truck back when I was restoring my 37. There was a TB out there somewhere that recommended additional oiler/splash holes to be drilled into the pistons for better top end lube.
combat32
106
Booneville AR.
out of the 6 pistons I got with my truck (motor rebuilt by previous owner) one has the skirt edge broke like yours, wonder if it was number 6? He didn't mark these as to which hole they came out of.
GUNNY 155
elgin illinois
I would say you are quite lucky. Most times when the skirt fails it is quickly followed by a catastrophic failure quickly followed by silence. I only saw one that stayed together in my mechanic days. Was it making any noise? I would be interested in seeing the TB on the added lube holes.
Texjun
Dish Texas
Thanks for your reply, no there was no noise engine was running OK for the little that I have run it, I think the cause may be that the person that I brought the truck from said that It had been sitting for some years, and that the mechanic that he hired had used ATF Fluid a few squirts in each cylinder before the engine would turn freely.
It was a total surprise when I dropped the pan and found the pistons.
I think I am going to get one each Standard Sealed Power Piston and a set of Mahle Original Piston rings from Summit Racing
I have inspected the other pistons and bore and there is no other damage.
Someone mentioned the TB and I have not seen a copy of it, If I come across it I will post it.
Regards Texjun
Bill W
Brooks,Ga
Texjun
I went through some of my old stuff looking for the TB ( which I could not find ) but during a search out to my barn stash I did come across one of the (used) pistons from my 1997 rebuild, don't have a clue why I still have it but your welcome to it.....I really need to clean out my barn!!
Texjun
Dish Texas
Bill W
That would be great, is there anything engraved or etched on the top of the piston such as .010 or .020 Etc.
You see my bores are standard at 3.250.
One of the great SS guys has sent me one and when I cleaned off the top it had .020 etched in it and I could not get it to fit into the bore.
Please let me know if it is a Standard and I will PM you my address.
Texjun
Texjun
Dish Texas
Thanks to a Generous Fellow Steel Soldier # 6 Cylinder now has a serviceable piston and rings installed so I can now start engine reassembly.
