Texjun
- 0
- 0
- Dish Texas
![M37 Piston -1.jpg M37 Piston -1.jpg](https://www.steelsoldiers.com/data/attachments/338/338331-a44511efe6acd45e7b16f15e07d5a541.jpg)
![M37 Piston -2.jpg M37 Piston -2.jpg](https://www.steelsoldiers.com/data/attachments/338/338332-0702cc05c5efee6f7f98c90138b61024.jpg)
![M37 Piston-3.jpg M37 Piston-3.jpg](https://www.steelsoldiers.com/data/attachments/338/338333-7e99c94da06529bf0d95657228ba5432.jpg)
I was just going to change Oil Pan Gasket, but they I found two broken pieces of Piston #6.
Only #6 has failed all other piston shirts and tops look good.
Has anyone ever seen a piston failure where the skirt broke off in two pieces and piston above the broken shirt started to cave in.
Overhaul Data-plate says pistons were standard at Rebuild back in 1972.
I took a quick measurement of the cylinder #6 with my caliper and got 3.248, there is no step wear at top of any of the cylinders.
Anyone have any take out Standard Pistons they could share I only need one?
Still looking, one of the great guys on SS send me one, but Unfortuneally it was not a Standard I need one good used STANDARD PISTON.
![# 6 Piston Broken.jpg # 6 Piston Broken.jpg](https://www.steelsoldiers.com/data/attachments/338/338274-3e2326612cca5890a62cbf399ad3f0c1.jpg)
![# 6 Piston metal in oil pan.jpg # 6 Piston metal in oil pan.jpg](https://www.steelsoldiers.com/data/attachments/338/338275-38ae843587ebd5db6caa3458219ab890.jpg)
![# 6 Cylinder no step.jpg # 6 Cylinder no step.jpg](https://www.steelsoldiers.com/data/attachments/338/338276-8d8ca63644339027471155a584356c00.jpg)
