For this recovery with the Ryder truck it was a solo mission, so I did not use the winch. Being that the winch is much easier with two people. I used two 4" x 20' straps on the front shackles attached to the frame of the box truck one on each side of frame rail. I dug out the wheel that was in the marsh as best as I could and made a ramp for that wheel, as well as dug a bit behind each wheel. Then I locked the front hubs and engaged the front axle. The driver of the Ryder truck put it in reverse and we slowly backed up.@DodgeTX How do you deal with the relatively low weight of the Deuce when you are winching other trucks of almost equal weight (such as the Ryder box truck in your pic) ? I find that staying on solid ground helps where I can chock the front wheels. But, generally, on unpaved ground the winch pulls the Deuce before the winch itself maxes out. Chaining the Deuce to a tree or another truck also helps in a pinch.
........ while risking an arm, or worse!?Today I regreased the front under the old torn zipper boot, replaced the zipper boot, and adjusted passenger front brakes. .......
Definitely go for it! Safety First! jackstand came later placed in both front and rear of leafspring 12ton jackstand. You can see in the picture with zipperboot on bumper......... while risking an arm, or worse!?
I'm tempted to photoshop your picture to make it look right - by placing a jack stand right there where that bottle jack is.
SAFETY FIRST, everyone...!!
Ah, good so! Just spotted its rack there (well hidden in the eye of the boot...).... Jackstand came later placed in both front and rear of leafspring 12ton jackstand. You can see in the picture with zipperboot on bumper.
Yes sir, I definitely should have put them in immediately. Pictures are not worth a broken arm leg back or truck!Ah, good so! Just spotted its rack there (well hidden in the eye of the boot...)
.Big red made it to our small town July 4 parade. Everything went well and it was a smooth drive to and from!View attachment 838935View attachment 838936View attachment 838938View attachment 838939
Yes with a little digging traction boards and a 6x6 most things are possible!.
That is neat!
Big Red seems have pulled that Enterprise Rental out of a mud hole with no sweat...
Pretty good sized trailer too. Maybe everything really is bigger in Texas?
Go Man Go!!
Have not had any issues with brakes sticking since that occurred. I think the brakes were out of spec then. After that tragedy with the fire I replaced the wheel cylinder, all seals, brand new brake shoes and cleaned everything to the best of my ability along with properly adjusting the brakes.Did you ever have any more issues with a brake sticking? I had that issue not long ago, on my way to the Haspin Rally. I almost turned around and went back home. The drum was so hot it was smoking like it was on fire. Took 10 bottles of water and 45 mins to cool off but ever since then, it hasn't given me any more issues. I was thinking it was the air pack myself because the pedal would be so hard to depress when it happened. I also drained the air tanks after letting it cool. Same wheel, same side as yours. However, I think that's awesome what you're doing with your truck. It's doing a job and when you're on the road, nothing but smiles per gallon, lol.
