dhaumann69166
- 77
- 28
- Hyannis, Nebraska
Having some wiring issues on my Humvee which led me to check voltage under the cover on the alternator. Wire 2A which is a small wire reads 14.2v while running. That would be correct voltage for a 12v system but I didn’t know the 60amp had any 12v outputs.
Wire 2A is the wire from ignition to alternator so I figured it should have 24v.
The other two wires (one big and one small) both are showing 28.4v which sounds correct.
Does anyone happen to know what the voltage should be at all 3 posts?
Any help would be greatly appreciated.
