If you added DOT 3 to your samples from the master cylinder and they settled out into two distinct layers in the container, then you have DOT 5 brake fluid in the master cylinder. You can buy DOT 5 brake fluid at better parts stores everywhere. I buy at NAPA because they are close. Be prepared, this stuff is pricey. I used just a bit more than 1qt. to fill the completely dry brake system on my long wheelbase civilian dual wheeled truck. By completely dry i mean new master cylinder, new calipers up front, new wheel cylinders out back, and all new plumbing in between. The "bit more than 1qt" included the losses from bleeding out the system. If your system already has fluid in the lines, i would think 1qt would be enough to get you filled up and bled out.
