nspctr1
- 5
- 18
- San Antonio TX
Doesn't look like the strikers would engage
Pictures are worth so much here. We'll be able to tell if any of the parts are wrong...something is bent...etc.OK, I purchased new handles and latches. The catch on the handle is at least 1/2" away from the latch. The latch is adjusted all the way out. I pushed the door from the outside while my buddy was inside trying to get the door to latch but no go. Is there a trick? Am I missing something?
Amen to that. I always have to give a good push to my one functional door. I'm going to straighten it up after I finish repairing the window stitching (or replacing...not sure yet). I'm just glad I only have to use ONE bungee cord while it's still sitting in the driveway, eating parts until it finally works.Get outside and push hard on the handle then turn to see if it will latch. Sometimes the soft doors get bent, and the top hits before the middle. You should not have to bend the strikers.
You also need to squish the gasket around the door.
Maybe flip the top roof forward and try again. If it closes fine like that, find the area of the top that is holding the door .
