Door hinge nutsert issue- how to fix?
Atchuuu
104
MS
The nutsert broke loose on a door hinge. I cut the head off thinking I could push it through the B pillar but the back of the bolt/nutsert is hitting the B pillar support. (See photo)
my guess is I have to remove the support to get the bolt out and to install the new hinge bolt. But before I go to all that trouble I thought I would ask for advice. Anyone have this issue before and how did you fix it.
thank you!
Atchuuu
104
MS
You could just weld the hinge to the remaining bolt
That’s a great solution. Didn’t even consider that. But I will likely remove the B pillar bracket so all of the hinge bolts are the same. I’m assuming there is enough room behind the bracket to get a bolt back there.
TOBASH
3,474
Brooklyn, NY
Alternatively, get a circular wood hole/dowel maker and drill out the area behind the bolt/rivnut and push through. Simple and fast and clean.
Cover with duct tape and paint drab green.
Atchuuu
104
MS
I pulled out the B pillar support bracket. Unfortunately, the nutsert is located in the raised channel of the pillar. So no access to the bolt. Drilled a hole behind the bracket and it’s just too small to retrieve bolt. Will get a larger bit and remove with a magnet.
could have cut the bolt shorter and let it fall in the channel but there is no way to retrieve it and I don’t want it to rattle around.
Atchuuu
104
MS
Update- had to drill out a 3/4” hole to remove the broken blind nut. Too tight for me to try to weld another nut in there so I if I ever have to remove this part of the hinge I will have to remove the B pillar support bracket again.
TOBASH
3,474
Brooklyn, NY
Weld a 3/4” arm to the nut. It will block the it from spinning. A dab of silicone or JB Weld, and it will stay in place for reuse.
[Edit - if you don’t have a welder, cut and tap a thin piece of flat stock that is 3/4” long. Then JB Weld or silicone in place.]
Atchuuu
104
MS
Great suggestion.
