Door Hinge pins
1,163
Hey Zak, how did you bend your sheet metal in order to make the patch panels?
Also, D-man, any movement of premade patch panels? :D
1,163
Shameless, shameless bump. :razz:
OD_Coyote
58
North Bend, WA
Does anybody know where I can get the door hinge pins, (their bolts really) when using the west coast style mirrors. I tried a couple of vendors but no luck.
I hope your hinge pins came out easier than mine did. Even after soaking them in PB-Blaster then removing the hinge from the truck, putting them in a vice and applying heat and a 3lb doublejack I could not get them to budge. I ended up buying new hinges from SS.
JCKnife
46
Kentucky
You can replace them with 5/16 X 3 inch bolts but will end up back in trouble with the hinges freezing up after a while.
The above mentioned kit I carry was something I devised after being fed up with my own doors as well as many request from others to come up with a bushed design which would work for both function and future disassembly without the need of a torch and hammer.
The technical article I wrote for these is here Steel Soldiers
After writing the article many complained that finding the mentioned bushings was more difficult than I anticipated and / or very over priced from what I mentored in the article so I put together the kit for the sake of obtaining everything easily.
If you are interested in purchasing the kit I do strongly recommend you FIRST READ THE TECH ARTICLE... This modification requires some level of know how with hand and power tools. It takes some "fiddling" and fitting to get just right but In the end you will have doors which open and close effortlessly with bushings that will last forever.
OD Iron LLC Military Vehicle Parts and Accessories Door pin kit....
Are these still available? Link is not working and I couldn't get the search function on the OD Iron site to work, either.
Tinwoodsman
77
Comfort, Texas
I just finished the hinge kit upgrade from OD Iron and it provides a super smooth action which can be removed when needed. I suggest you do the hinge drilling with a drill press if possible but it is not mandatory. Good luck.
JCKnife
46
Kentucky
Got a link? I can't find ANYTHING on their site. Bunch of dead and do-nothing hyperlinks on the home page, I feared they were out of business!
No phone number listed; contact form does not work. Man, that is one broken website!
Tinwoodsman
77
Comfort, Texas
You are right. Their website is screwed up. I ordered my kits one year ago and they cost $32.98 plus shipping for both doors. Their part number is hngkit001 My receipt did not have a phone number but I contacted them at: sales@odiron.com
Good luck.
Heavysteven
11
Hickory Flat Ga
I had to replace a couple myself. Got a couple used ones from Tom CSI in Tallaposa Ga.
I tried to take the bolt to a Metro Bolt but the treads at the end are recessed. Old ones fit in perfect and I did not have to remove the door.
Warthog
245
OKC, OK
OD Iron is currently "out of business" until some internal issues are resolved. Hopefully it will be soon.
gimpyrobb
dumpsterlandingfromorbit!
27,791
787
Cincy Ohio
Joe, I might have a pin or two, but you'll have to remind me Monday morn to look. This weekend is busy at work.
Wildchild467
59
Milford / Michigan
The specs for the door bolt are:
THREAD LENGTH
0.620 INCHES MINIMUM
NOMINAL THREAD DIAMETER
0.250 INCHES
FASTENER LENGTH
3.250 INCHES NOMINAL
SURFACE TREATMENT
CADMIUM OR ZINC OVERALL
HEAD HEIGHT
0.210 INCHES NOMINAL
HEAD STYLE
HEXAGON
THREAD QUANTITY PER INCH
THREAD DIRECTION
RIGHT-HAND
SHOULDER DIAMETER
0.2800 INCHES MINIMUM AND 0.2810 INCHES MAXIMUM FIRST SHOULDER
MATERIAL DOCUMENT AND CLASSIFICATION
SAE GR 5 ASSN STD SINGLE MATERIAL RESPONSE OVERALL
SHOULDER LENGTH
2.560 INCHES NOMINAL FIRST SHOULDER
THREAD SERIES DESIGNATOR
UNF
MATERIAL
STEEL OVERALL
WIDTH BETWEEN FLATS
0.500 INCHES NOMINAL
SURFACE TREATMENT DOCUMENT AND CLASSIFICATION
QQ-P-416,TY 2,CL 3 FED SPEC 1ST TREATMENT RESPONSE OR QQ-Z-325,TY 2,CL 3 FED SPEC 2ND TREATMENT RESPONSE OVERALL
SHOULDER SHAPE
ROUND FIRST SHOULDER
THREAD CLASS
2A
It would be neat to make some, but they are an oddball spec for sure. if somebody had a lathe, i bet they could make a couple up without too much problem.
JCKnife
46
Kentucky
Memphis has standard hinge pins in stock. I was just hoping to get those modified OD Iron ones that seem to be better. But since they are Tango Uniform I'll go ahead with the pins from Memphis.
AceHigh
31
Lake City FL
Removing the old ones involved heat, PB blaster, small back and forth movements, more heat, more PB blaster, more small movements. If you hammer it from the bottom it will quickly mushroom even with the nut on the end.
Once I got them out I drilled the hole and put in a new off the shelf bolt. I forget the size.
