Door sag
kendelrio
8,949
Alexandria, La
Ok gents-
I've tried and tried, but I cannot seem to get the sag out of my driver's door.
I've adjusted the hinges (I have found they move them in and out)
The doors themselves
And in the process got the gap too tight (Note the chipped paint)
I cannot seem to get the gap correct and have a good level door.
If I get the door to where it doesn't droop, the gap is too tight. If I open the gap, the door drops
Can someone please explain to me like I'm 5 how to adjust the thing please?
ZiggyO
484
Nebraska
I am willing to bet the pin on the upper hinge of the drivers door is shot-- We see that in my inlaws' body shop quite often. It makes sense that the driver's door is showing the issue and the pass door is perfect-- the drivers door sees the most use and many times is also used as a form of leverage to get behind the wheel.
Pull the hinges and sight down the hinges vertically-- I bet the pin is worn out or the hole worn to an oblong shape.
Z
kendelrio
8,949
Alexandria, La
Z
So the fix for that is a "new" hinge?
ZiggyO
484
Nebraska
So in the auto body world, new hinges are the fix-- however, in the event that the hinge is not readily available, we use bronze bushings . It will require the services of a machine shop, but essentially, the hinge is drilled out on center, bushings pressed in, and a new pin inserted.
canadacountry
681
Canada
@kendelrio this is offtopic but when I noticed your saga I thought of an unrelated but similar headache-ish from my one trabant book..turns out that they fit the "raw" duroplast door panel onto a car then sandblast it to exact size hence since every car is 'bespoken', 30+ years later taking the driver door off one car and putting it onto another car does not always 100% fit well right away for this particular reason!
kendelrio
8,949
Alexandria, La
Interesting!
Barrman
1,973
Giddings, Texas
With the door open. Do you get slop at the hinges if you pick up on the handle end? If so, try to see if it is the upper or lower hinge. Possibly both.
If no slop then it comes back to the cab being tweaked or as mentioned above the tolerance of the cab and the tolerance of the door being at the opposite ends of the spectrum and it just doesn’t fit right. Another wild thought is the body mount bushings. I am sure they are dried and degraded. Maybe one so so smooshed the cab has deformed?
kendelrio
8,949
Alexandria, La
I meant to update earlier... i left the shop last night and my buddy went TO the shop and adjusted it for me. The freaking thing is perfect now.
Tomorrow I'm going to hem him up and force him to tell me what he did! 😁😆😅
