- 281
- 221
- 43
- Herriman UTAH
So the doors in these trucks are stopped from flying open all the way by a strap at the inside bottom of the door. My strap was broken like this.
![IMG_20200110_153453.jpg IMG_20200110_153453.jpg](https://www.steelsoldiers.com/data/attachments/543/543424-8a537d66cc115a8bee6532fc9cc4659e.jpg)
The driver door would get caught by the wind, fly open, and hit the mirrors. The old strap was 2 inches wide and black. On Amazon, I found a 2 inches brown strap at a good price so I bought it and hoped it would work.
![IMG_20200110_151826.jpg IMG_20200110_151826.jpg](https://www.steelsoldiers.com/data/attachments/543/543425-772ef521294af62e023d735f644ee9f7.jpg)
I like the brown color better than the black. So I pulled all the pieces apart and then figured out how to fix it. I then realized that all I needed to take off was the plate with two bolts at each end. After removing the bolts, the plate will not come off because it is glued. So I used a chisel to break the plate off and then used the bolts to put it back on without any glue.
![IMG_20200110_161742.jpg IMG_20200110_161742.jpg](https://www.steelsoldiers.com/data/attachments/543/543427-3b9eb0338479dcf9f0b8f85630935808.jpg)
I cut the strap in half to get the correct length and so one strap will fix two doors. I have half a strap left if anyone needs to fix their door.
So the bottom line is that it worked great and it is adjustable! The original strap was not adjustable.
![IMG_20200110_163542.jpg IMG_20200110_163542.jpg](https://www.steelsoldiers.com/data/attachments/543/543428-2babe1b69d90324499114753334e7a7e.jpg)
