AJMBLAZER
- 7
- 0
- Paducah, KY
So somewhere in the meantime since I last checked my brake fluid my parking brake light has started coming on intermittently. Brakes still seem to work fine.
Checked the reservoir on the master cylinder and the rear is mostly full while the front is very low...
...which I think means the fluid is going to the rear...right? Maybe the shoes are worn down?
No visible leaks that I can find.
At any rate, while I dink with this, I've never had a DOT 5 brake fluid equipped vehicle before. If it turns out to have DOT 5 in it does the true DOT 5 stuff at the parts store mix fine with the DOT 5 that ought to be in it?
Going to go do the test now to see what I have.
Naturally this all happens as I'm starting to daily drive it for most of the next month.
