Drag Link Kit from Memphis
dabtl
Denton, Texas
I put the $38 drag link kit from Memphis on the deuce today.
The old sockets were so worn the lube grooves had disappeared.
I am not sure it made a big difference in wheel wobble problems but with the steering gear rebuilt and the new tie rod ends, the steering will be virtually new. :)
doghead
4 Star General /Moderator
1,193
NY
Good info! I'm glad you found the bad joints and you were able to fix them. I see on your other post you also had a loose front axle on the leaf-spring.
Blood_of_Tyrants
11
Lebanon, TN
Make sure it is aligned properly, too. Poor alignment can cause shimmy problems as well as a feeling the steering wants to dart off to the side when you turn.
dabtl
Denton, Texas
The alignment may be the problem. The wedges put in required loosening the u-bolts. It would appear they were not torqued properly. Now, I am getting new lock washers and a morning putting them on will most likely solve the problem.
dabtl
Denton, Texas
Re: RE: Drag Link Kit from Memphis
The drag link is a 30 minute repair if you have a parts cleaner. I have my son. It took a little longer.
The wear on the ball sockets was easily seen. Without lube they would wear even quicker.
Memphis has about 400 of the kits in stock at $38 or so. A good preventive measure for an afternoon.
