gimpyrobb
dumpsterlandingfromorbit!
- 27,791
- 785
- 113
- Cincy Ohio
Its just easier that way. You don't have to worry about the wheels turning, don't have to worry about the pinion flipping over, pull the bolts that hold the leaf spring pins(then tap the pins out) and lift it up. The brake line and pitman arm were the only other things that needed disconnection. I was going to undo the U-bolts, but your not supposed to re-use them. Stretch mentioned doing it this way and it worked great. Should be interesting to see how hard it is to line everything up to put back. I will let you know tomorrow, I hope.Outstanding, you disconnected the axle and moved the truck.
Will you be my neighbor?
