- 143
- 157
- 43
- Los Angeles/CA
I've been looking at F-13 and F-14 in the -20 TM for about 2 hours, but I dont understand what the diagram is saying.
All passenger side marker and turn signals on the truck work.
The driver side parking light and rear turn signal works, and the side marker light flashes when the turn signal is on. However it does not illuminate when the headlights are on without the turn signal being selected. Also the left turn indicator in the dash never comes on, and the bulb is known to be good.
When the headlights are on, I have 12v on .8 BRN-9B and .5 LT BLU 14B is floating. Obviously this prevents the bulb from illuminating.
When the turn signal is engaged .5 LT BLU 14B is momentarily grounded to illuminate the side marker, and then connected to 12V to turn off the side marker and flash the parking light.
On the passenger side I have 12v on .8 BRN-9G and .5 DK BLU 15B is grounded, so the passenger marker light illuminates. It flashes the same way as the driver side, and works properly.
What is supposed to ground .5 LT BLU 14B when you turn on the parking lights or headlights? Is this one of the contacts in the turn signal switch (top left of F-14)?
Update: I tried replacing the turn signal switch because I had one laying around, but that didnt fix the problem. I dont have any idea what else to try. If anyone understands how this system works, I;d appreciate any tips.
