driving today truck starting vibrating
jdeoliveira74
wilmington nc
So today I drove aprox 2 hrs before needed some fuel. Made stop fueled up got back on road. Truck starts vibrating and almost bouncing. Felt like truck was studdering or shuttering. could feel vibration in seat and steering wheel. I did check drive shafts everything seems ok. tonight it ran fine. Possible causes?? I am thinking ip pump or injectors? fuel filter is new
camogriz
Carmel, NY
You mentioned that you just fueled up and were wondering if the ip or injectors were the problem. Could you have pumped in some bad fuel?
jdeoliveira74
wilmington nc
Well i come home tomorrow. Friday morning I plan on doing motor mounts and transmission mounts. Greasing all suspension and drive shaft and fixing leak on transfer case should be a fun filled day of wonderful words coming out from under my truck. I guess thats a start. Havent really had any issues since the last time. I guess I will go from there. Thanks for the help guys
jdeoliveira74
wilmington nc
Get your drive shafts overhouled and ballanced!
Get your wheels ballanced.
Do not try to do these jobs at home!
Wolf
So you were right. yesterday I was out of town and my drive shaft broke at the front u joint. 152.00 later i was up and running in a couple of hours.
I had them replace the front and rear !
thanks
wish i would have been able to service it on the road before it happened
