Droolguy's 1984 M1028 issue tracker.
Droolguy
La Pine, OR
Hello everyone,
I am just posting this thread up so that I can keep track of issues related to my new to me (2 days old) CUCV and ask for help without making a ton of threads.
If you read about an issue and it doesn't have "solved" next to it in the list I have below I still need help either figuring out if it is normal or fixing it.
Bear with me as this is my first diesel ever so I really don't know what is normal.
Thanks everybody for your time, and I look forward to talking to you all.
1. Light blowby at oil fill, apparently normal.
2. Screeching GEN2 alternator belt, solved, tightened.
3. GEN 2 warning light on when vehicle off, stays on after engine starts, goes off once engine warms up seemingly at random, meter in truck shows neutral charge when light is on goes to just a hair below the mark in green sector when light turns off.
4. Ringing sound coming from oil fill tube when the cap is off. Normal or issue? VIDEO @ https://drive.google.com/open?id=1Z3WKjZXa3saWARyMpscWhGipEtS8Hop-
5. Glow plug wait light takes almost 20 seconds to go off on first start of day @ 70 degrees outside temperature, normal or issue?
6. Very hard starting first start of day, regardless of temperature. Crank for 15+ seconds before fires. Need to use throttle to keep from dying after start until it rolls up to operating RPM. RPM slowly increases until it levels off, then can release and it will idle.----6a. Has fuel leak, can contribute to air in fuel lines according to SS search, will troubleshoot.
