Drop tank for rear bumper brackets? (M1009)
231
Mount Laurel NJ
Does anyone happen to know if the fuel tank needs to be removed to remove the rear bumper brackets on an M1009? I am thinking about making my own bumper but would need to remove all the original components. Thanks!:D
cucvrus
10,427
Jonestown Pennsylvania
The rear bumper outer brackets are 7/16 X 14. The have caged nuts that are integrated into the rear cab mount isolators. They are usually rusted to the point that the bolts/nuts will break before they come loose. In the event that happens you will need to eliminate the nuts. I have used 1/2" nuts with a small section of flat steel welded to them to act as a wrench when tightening the brace bolts. You can also reach in and get nuts on with the bumper off and reattach the braces before the bumper. tricky challenging work. But easy enough. May I suggest power tools. Cordless / pneumatic impact. Hard ratchet never happen without a box of band-aids. The torch works best. Being careful. A torch is only as unsafe as the operator. I have been welding on new vehicles for 30 years. Some fuel tanks are 3'' from the welds on the frames. Very carefully. Have a Great Day. Be Safe.
