Dropside Hardware
jonesal
Mission Specialist
74
Brookings, SD
I'm trying to figure out the stock configuration of the hardware (retaining clip and anchor pin setup) between the long side rack and short side rack of a dropside. I have most of the parts collected but do not know where the "S" clips from the chains attach that retain the pins and clips. The hardware is parts 15 through 20 on the first picture and my question is where do the "S" clips attach from the chains on parts 16 and 17 of the second picture? If anyone would post a real picture of a stock setup, that would be appreciated. I can guess how to bend the "S" clips to make something work, but would like to do it right.
I'm still looking for 4 of the brackets, part 18 in the first picture. Any leads is appreciated.
Thank you,
Allen
'84 M923
jonesal
Mission Specialist
74
Brookings, SD
Fantastic! Thank you. I have found all the parts except the two "half moon" brackets (four total) that hold the loop on. If I find those, I be in business. Thanks again - now I know how it all bolts together.
Al
'84 M923
