engineman2
- 2
- 18
- Enon, Virginia
My passengers rear brake locks up very quickly when in slick conditions. If the road is wet/it's raining or I'm on mud and I even tap the brakes the rear passenger tire will skid. I've been having this issue since I bought the truck a year ago. It had a leaking rear axle seal so I replaced that and in the process rebuilt both drums (springs, adjuster, wheel cylinder, etc.) and put on new Napa shoes. Afterward I bled the brakes according to the TM. I was hoping this would fix it. It didn't so I bled the brakes again and took off the offending drum twice to try and figure it out. I couldn't. So, I think it might have something to do with this rednecked proportioning valve riser that someone made when they lifted the truck. It has a 4" lift and, as you can see in the pictures, the bracket sure hasn't been raised 4 inches when compared to my 4" long Leatherman. I would think this should give me less braking since the valve would probably be less open when farther down. I'm at a loss. Sorry this was so long but it helps to be thorough. Hopefully ya'll can figure this out, Thanks.
