Hainebd
- 5
- 0
- Mays Landing, NJ
Is anyone doing this? One circuit to wheels, the other to pinion brakes.
Aaron check out this site. At work we had these on our older 40ft busses. They can almost bring a fully loaded bus to a complete stop. They make them for all kinds of applications.I've wondered about just having a pinion brake (with a separate pedal or hand lever) to use as a last resort emergency brake in case of a hydraulic system brake failure (ruptured hose or something).
Would 1 pinion brake on the front axle (assuming no lockout hubs) or center axle be enough to stop a deuce within say double the distance that the service brakes could? I understand the brake may be completely shot after this one use, but its got to be one of the most affordable ways to have a redundant brake assuming it could do the job even once.
The issue is twofold, mass and cooling. Take the six drums off a deuce/five ton etc and weigh them. That is how much mass you need in the pinion discs. Plus cooling which SHOULD be easier as the pinion is turning so fast. But as nearly all pinion discs are solid, not vented, they overheat like Rosie O'Donnel in a confessional box.With the ceramic disc and pads along with 6 piston calipers it may work. It would assist and be second circuit. The big issue is not allowed on street by DOT and/MV.
I don't see why you couldn't put a disk on each pinion flange. Keep in mind each time you add one this is more $$$$. So how many would it take to make a useful emergency brake and how much would such a system cost?You can't put two pinion brakes on each rear axle and gain some performance?
Boyce sells a pinion kit for $300ish right so I'm sure you can easily get a caliper and disc for under $100, a hydraulic handle like below for $100 and someone to make some laser cut weldment (if it can't be flat stock) brackets.I don't see why you couldn't put a disk on each pinion flange. Keep in mind each time you add one this is more $$$$. So how many would it take to make a useful emergency brake and how much would such a system cost?
I might be incorrect on the Mazda/ford ranger disk. I thought that's what they told me but its been a while. It is definitely off of something that has 4 lug bolts. I do remember the disk they showed me was an off the shelf duralast rotor from autozone.Boyce sells a pinion kit for $300ish right so I'm sure you can easily get a caliper and disc for under $100, a hydraulic handle like below for $100 and someone to make some laser cut weldment (if it can't be flat stock) brackets.
Welldigger, Why do people use Mazda brakes? Do they just happen to have the right pattern on the disc?
Thanks Greg, I just shot them an email for some rough pricing. Maybe I'll call this Mico company also, they are 2 hours away from me and perhaps could offer some suggestions. https://www.mico.comAaron check out this site. At work we had these on our older 40ft busses. They can almost bring a fully loaded bus to a complete stop. They make them for all kinds of applications.
http://www.telmausa.com/products/operating-principle
