Dual circuit brake using pinion and wheel brakes.
Hainebd
Mays Landing, NJ
Just thinking and I am sorry for bringing this topic back up but why not put 6 disc brake pinion brake system on. Two per axle.
peashooter
205
Hanover, minnesota
Maybe you could but what's your reason? I think we must all have different goals for pinion brakes, my goal would be to have a last resort emergency brake as simple to install and $500 or less....dot approval not important since its emergency/parking use only.
welldigger
15
Benton LA
For just a parking brake 2 disks on whatever 2 pinions you choose would be a vast improvement over the stock deuce parking brake. And would work well in conjunction with the stock park brake.
For an emergency brake I would think a minimum of 4 disks. Even then I would imagine one shot and they are toast.
ke5eua
41
Baton Rouge (Central), LA
I emailed a place out of Louisiana about the calipers they use. Seeing if there is an oem version that will bolt up to their kit that will offer a parking brake option. I'm not entirely to keen on the rotor design as it has the company logo in it but for the price it's not to bad, both 2.5 & 5 ton is 350 for a complete kit.
welldigger
15
Benton LA
Wouldn't happen to be krypyonite kustums would it?
ke5eua
41
Sycotic Fabrication out of Carencro.
Personally I think for our applications converting the drum to disc on the parking brake would be ideal, at least that is what I'm going for. Also air disc calipers are way expensive. Can get a air brake pack and fab up a bracket to pull the tension on the caliper and do the same thing for way less. That's what I'm planing on doing with my parking brake but if I can go disc I will be happier than a gator with a toothbrush.
welldigger
15
Benton LA
If you just want a disk parking brake I would put 2 hydraulic calipers on one disk behind the transfer case and have a hydraulic parking brake. It would be simple and almost fool proof.
ke5eua
41
Biggest thing is the rotors, what lines up to the pinions, both 2.5 & 5 ton.
I was under the impression that holding pressure on hydraulic brakes for long periods of time isnt recommended.
If I could do that I would put a line lock on the front drums instead.
welldigger
15
Benton LA
Hmm ya a mechanical caliper might be a better option. I'm not really sure what one of those would cost. I think on a deuce you could use the same rotor as a pinion brake. 5 ton I don't know.
rustystud
2,962
Woodinville, Washington
There are trucks that use a caliper as the parking brake ( in fact some of our "Ford baby busses" used them) . The park lever pulls a cable that actuates a cam-over block that presses on the caliper ( picture a large vise-grip). I have worked on them before. Pretty simple, but I wouldn't trust my life to them. Of course in an emergency I would use anything at my disposal !
peashooter
205
Hanover, minnesota
I think I'm going to try making a "last resort" brake and I'll see how it works. I'm thinking 2x rotors (12") with 2 calipers each. Both rotors mounted to the center axle's pinion. If it works and ever gets used, then replacement rotors should be all that's required.
