Dually Conversion (For looks)
wayne461
Valley Cottage New York
I needed a front axle anyway. The ring and pinion were dust, and the king pins were also gone. I think I paid $350 for the adapters and another $800 for the 19.5 wheels. I initially bought the 19.5 wheels to fit over the brake drums, but I got a disk brake conversion about mid stream.
1,827
Wouldn't it be cheaper to buy a M1028 dually?
How much does all this parts swapping cost?
Have you priced an M1028A2 or M1028A3? Awful lot of money to do a swap. I did my shop truck in my avatar for around $250. $150 for front rotors and $100 for the chassis cab rear. Swapped over the Detroit NoSPIN.
319cssb
221
Easley SC
How much is a 1028a3?
The m1028 dually also have fender flares.
1,827
A decent one will set you back $7500. Basket cases usually sell quick at $3000. Problem is that there aren't many to choose from.
If I were to set out to build a CUCV pickup into a dually, I'd start with front rotors. There are any folks in the 4x4 world willing to trade rotors/hubs. Likely could be done even up. I see Dana 70 rears out of 2WD trucks selling often. Finding one with 4.56 gears might take a spell. I think high end would be $500 (more than I'd pay). Myself, I'd try to find the wide 14 bolt from a 90s dually and remount spring perches. I could swap over the locker from that. A orkable civilian bed could be had for $400/500. The other route is the spacers and they have worked in the past, just not something I'd do.
MasterSweeper
Michigan
Its been a while but here i go put the dual hubs on, bought two inch spacers and viola. Monster cucv need to see about finding a set of dually fenders or going either flatbed or utility body. Running four 37 hummvy tires in rear and two of the new mtr's in front.
Just wondering if them Humvee tires fit on the stock dually rims?? If i remember right those rims are very narrow.
319cssb
221
Easley SC
I've had 3 M1028 a A2 and two A3 I bought all of them for between 2400-3400. They weren't basket cases, but still required some PMSC. I sold all of them for $5500- $6500.
How about buying one and swapping the parts you want over to your M1008 or whatever and sell the M1028 as a M1008? I am sure you can at least get the parts for free by doing that.
1,827
That could be done as well. At that point I'd keep the M1028A2/3 as long as it was a solid truck. I have a thing for the chassis cab rears. While its still a dually, not a dually truck but all I have here is the SECM which already has one and the ambulance which, if it doesn't sell, will get one!
319cssb
221
Easley SC
I see. I always liked the pick up with fender flares. Not the civilian, but the woodland camo version.
