- 7,426
- 2,537
- 113
- Interlachen Fl.
You crank one of these trucks to long and you will be looking for a starter. And at 79 lbs they are a lot of fun to get up out of there. Plus they are not cheap.
Will is correct you can just crank her over till the can fills. If the system is tight with no bad rubber or air leak points then crank. You do not have to crank it till you over heat the starter and you don't have to do all the cranking at one time. These starters will easy crank for fourty seconds with out getting to hot. Then just walk away and smoke a cig or what ever you have then call the wife or girl friend and tell them how you feel. Heck smoke another cig if you got one cause the fuel that has been pulled out of the tank to the canister is not going anywhere. Now go back and crank for another fourty and see if she will fire and if not repeat step one this time work on something else or get out the grease gun if she needs greasing. Get the point
