Manstein
Chaplain Emeritus
- 331
- 4
- 0
- Cartersville Ga.
My e-brake doesn't hold. The adjuster on the handle is tightened as far as it will travel. I loosened it about half way and crawled under the moose and tightened the adjuster till the brake linings began to touch the drum. When I applied the brake it still would not hold even with tightening the adjuster on the handle in the cab. So, I slithered back under and tightened up the cable further. At some point I crossed the threshold where even released it was dragging. I finally wound up loosening the adjuster on the cable at the brake back up which lets me drive but still no e-brake. What did I miss?
