East coast to West coast trip - Free part taxi - standby assistance requested
TechnoWeenie
1,805
Nova Laboratories, WA
You are in Minnesota now?
Middle of SD now...
50ish... Around 2000rpm...
Actually getting closer to 6 mpg than 5... Thanks to flat land..
Some hills in PA and WV I was going 25 mph up.... And couldn't go faster...
I predict some more of the same in MT...
Biggest issue is the seat.
Spring sucks. Shock is shot. Foam is toast..
Added 2 seat cushions from Walmart... Still not good.
I'm wearing ear plugs but I still hear the engine running after I shut it off... And dream about it... :p
Another Ahab
4,944
Alexandria, VA
Middle of SD now...
A photo of the territory now and then would be SO sweet.
Could you maybe "click" a pic or two!?
Alaskaboy
Ketchikan, Alaska
Found a good air dryer if anyone needs one, going to order one before I make my trip.Try ebay search 24V HALDEX ABS AIR DRYER
TechnoWeenie
1,805
I gotta change all the fluids (again)
I'm going to replace both fuel and oil filters with spin on
I'm gonna replace the air lines with synthetic rubber and standardize the dimensions. Each line will be on a barbed connector with hose clamp so replacement will be easy if necessary.
I'm going to replumb the air system, making each tank with its own blowoff valve, and shutoff valve, so all the tanks are connected yet separate. I can isolate a tank or line in the event of a leak or failure. Each tank will have a check valve as well.. Incoming air cannot escape the way it came in. This way if there is a leak upstream, I still have all the air in the tanks, instead of watching my needle drop like a rock...
Lots of other stuff... But first things first..
TechnoWeenie
1,805
Also.. The warning buzzer can't be heard with good ear protection on.
It will be replaced with a 120db warble alert.... With a cutout switch so I don't have to hear it once the problem has been identified.
porkysplace
1,496
mid- michigan
You probably should research the D.O.T regulations before altering the air system , unless your truck will used off-road only .
Plane Fast
Panama city FL
Oh, and I think if you just change out the check valves and update your air dryer. (And possibly the PPV) All your air problems should be good. It's not a bad system when it's maintained.
TechnoWeenie
1,805
I'm not much for rules and regulations.
Safety is more important to me than the 'right' way. If it's safe, do it.
No warrant, no inspection.
Wanna crawl under the truck? Don't complain if you get run over..
All I know is I had 3 air related failures... And I want eliminate future failures of a critical system and provide rapid fixing of a failure should it occur.
Nothing I proposed would impair safety... Quite the opposite, it would improve reliability of a critical system.
Adhering to 50 yr old DOT guidelines (fmvss anyone?) when better, more reliable, and safer, technology is out there, is dumb.
That's an argument for another thread. I'm not required to undergo DOT inspections.. So that's not an issue either.
TechnoWeenie
1,805
My concern is the lines blowing out... Rather.. One line blowing out twice...
If one will, others will.
The lines were sitting for at least 7 years and plastic gets brittle over time...
reset2
100
Myersville MD
Well glad you made it back home. Im sure it will be a while before you make that trip again but if you really want to sounds like Alaskaboy will have an empty seat. :) Overall your trip was not a total loss. If you remember when we hooked up my air grinder to cut the holes in the bumper for the lights a lot of water and rusty water that came out. After working on my 5 ton dryer couple weeks ago and what happened to you on the trip if anyone out there is planning on a trip take a new air dryer for insurance.
