Joeinderry
- 1
- 0
- Derry/NH
Removed the rear suspension on my 3rd project bobber (in under an hour) it gets easier everytime. I also cut off the rear section of frame. This will have an M105 trailer bed on it. I'm leaving space between the cab and bed (like Hanksdeuce)so I can have a place to put my acetylene and oxygen cylinders. I will also be adding a multiuse frame behind the cab to mount some overhead off road lights and hang chains and equipment. I have some 49" tires mounted on MRAP rims (from Vintage Iron) and the adapters from (Peashooter). Ill be using front springs for suspension. This deuce has under 13k miles, multifuel, c-turbo. Ill be replacing the hardtop, windshields, seat covers, drivers door, radiator, and doing some metal work. Also adding dome light, backup alarm and backup lights, extra marker lights, etc,etc....
