Eaton fuller 8LL?
minigunmike
Defiance Ohio
Hey guys probably a stupid question and I'm sure I didn't look in the right places but from what I've read the multi fuel is a sae 2 pattern engine to the bell housing? I was thinking of ways to have a lower low range. It was brought up to put a highway truck transmission in so you have the high/low from the transfer and transmission. I'm sure someone has done it but I'm not finding it. :/
Jakob
Louisville, KY
I have passively saw a lot of talk about it around here. It seems like the general argument is that the transmission will be too long to keep the transfer case and still have reasonable driveshaft lengths.
minigunmike
Defiance Ohio
Been going through so much information today it is all coagulated hard to remember what's what! I was thinking about the shaft from trans to transfer and thought if it could be married somehow that might just give up the few inches itd need. But then back to the bell housing debacle... Somehow I stumbled across a article on a deuce trans in a 715 with a gm big block. Very interesting and awesome looking.
Anyway the the deuce has a sae #3 then? Might have to look at medium duty truck transmissions
gringeltaube
Staff Member
2,276
Montevideo/Uruguay
Yes, it has an adapter ring: the smaller (transm.) side is a SAE#3, but the eng. side is an odd pattern - not a SAE #2
minigunmike
Defiance Ohio
I at least remember that! Lol it's like a sae 2 but a bolt or 2 don't line up or something. I remember someone had to have it all laid out and machined. These things are big tinker toys. It's just a matter of finding the right parts to mesh it all together
rustystud
2,389
Woodinville, Washington
Why couldnt you slide the transfer case back to clear the transmission?
You could move the transfer-case. It would be a lot of work and very costly as both drivelines would have to be modified. Also your linkage would have to be modified and your truck bed possibly modified for clearance also. There really isn't any transmission out there except the Spicer 3052/3053 that fits unless your willing and able to do a "lot" of modifying !
Personally I'm looking for a 6000 series 3 speed Aux gear box to put behind the transfer-case. Very hard to find one out here.
gimpyrobb
dumpsterlandingfromorbit!
27,785
747
Cincy Ohio
Mike, I have a T-case option for you. It has a 2.45:1 low vs the stock 1.198:1. Same 1:1 high range, a built in pto and its all air shift solenoids, no linkage to fool with. Call if you still have my number, if not, send a PM.
gringeltaube
Staff Member
2,276
Montevideo/Uruguay
Thanks, Rusty.
Guess I'd better add a PDF-version then...?
(actually I always upload them as PNG but its the server that then converts it to a blurry, low res. jpg)
rustystud
2,389
Thanks, Rusty.
That would be great actually ! I have all your transmission and transfer-case graphics in a special binder. The others go in the regular Deuce binder.
