Poccur
- 131
- 43
- Roanoke, VA
That governor controller has gain and stability controls. We typically use that one with the 35kW unit but it should (in theory) work in a similar fashion on your Lister..
Turn the stability up (clockwise) until the engine starts to 'hunt or bounce'. dial it back until it gets stability then go two more notches back (counter clockwise)..
Do the same for gain...
Try that for ability to handle loads...you should find it is about the best setting but like I said, typically that gov controller is on the 35kW/Deere engine...be interesting to see how that works..if you viewed those dials (gain and stability) as a clock face, what time are the pointers lined up with when you are done?
Best
Poccur
Best
Poccur
