El Paso M109A3 inspection/need help with lights!!!
FMJ
37
Las Cruces, NM
I went down to look at my trucks again today with my Dad, but this time I took my M1008 and slave cable......
All 3 started easily, all 3 move, and all three have brakes :D :D :D :D :D so when I get my EUC the recovery will be...wait, nevermind.
One problem on one of the trucks, this pad for the control of the lights would not light up, or operate the exterior lights, and when I started messing with it the oil pressure, and temp gauges pegged out low......any thoughts?
FreightTrain
Banned
2,730
13
Gadsden,Al
RE: El Paso M109A3 inspection
Sounds like the gremlin awakened in the pushbutton.Don't know about the gauge problem though unless there a crossed bare wire under there.You did hit the wanted light setting and then Enter right?You gotta push one then the other withing a set amount of time(3 seconds?) for it to work.Even though it should light up just by pushing a button but it might have been to bright outside to see it.Try pulling a triple tree and install it to see if it works.
quarkz
Supreme Galactic Cleric
71
Kennewick, WA
I though these were known to have grounding issues.
Check for an extra ground connection t one of the mounting screws or the othe end of the ground for a loose connection.
You could always take a spare analog version with you an swap it our before driving it back.
Maybe a switch from one of the others.
FMJ
37
Las Cruces, NM
On the first truck the pad works, hit service lights, then enter, no prob. when you first hit the pad it lights up blue I think, the second truck nothing, no lights on the pad at all.
This is the first time I've sat in a Deuce and the first time I've started and driven one, I was smiling from ear to ear..........I think I've caught "THE BUG".....
Man I'm stoked about this...... :D :D :D
FMJ
37
Las Cruces, NM
Re: RE: El Paso M109A3 inspection
So there is nothing special about this pad?, it will swap out with the analog switch version?, one of the trucks has the analog switch, maybe I'll pull it. 2 of these will be driven, one towed. I will have magnetic lights for the towed 109
bulldog_mack13
3/3 ACR
2,968
34
Colo Springs, CO
RE: Re: RE: Re: RE: El Paso M109A3 inspection
Yeah , i have fully working pad for my m37 and have had no problems , but we got it out of a humvee at work and my buddy a truck mechanic in my unit put it in for me.
