- 2,746
- 2,391
- 113
- Sunman Indiana
I would guess close enough, but there are plenty of choices to weed through the specs on. Don’t hang up on port size either, you can easily bushing down 1/4.
In what scenarios do you the manual mode in? I just installed my setup the other day but didnt instal a manual switch to override/bypass the thermal switch.Yep, works fantastic, especially in the hills. I use it manually a lot more than I thought I would.
gotcha. i guess it would be a good thing to have for extended rear pto operations, sitting stationary.Use it to help brake going down hill. Run it before going up a big hill to pre-cool the radiator, then turn it off when when the fan kicks on right as the truck is falling on it’s face near the top of the hill.
Not necessary, the thermal switch will work fine for that situation… nothing to gain.gotcha. i guess it would be a good thing to have for extended rear pto operations, sitting stationary.
Gotcha.Not necessary, the thermal switch will work fine for that situation… nothing to gain.
