I was finally able to do some hot weather testing on the electric cooling fan and the new, less restrictive fan mount.
After much experimentation I have to say the project was a success AND a failure.
It is a success in that it offers a solution for cold weather slobbering and inability to heat up past 120 degrees in the winter. It is a failure in that the single 2360 CFM 16"/16hp fan isn't quite enough to make me feel comfortable on an 80 degree day.
As previously stated, I'm using a Spal 24 Volt 30102540 VA18-BP70/LL 16" High Performance Push Model --- Straight Blade fan. It is rigged to come on at 195 and off at 175.
On a hot 80 degree day (by Northern Minnesota standards) the fan stays on all the time and temps hover around 195 degrees. In a hill it's easy to get to 200, even 205. This makes me nervious in that I feel I'm sailing a little too close to the wind. I get worried when the needle goes over 200 degrees.
With the current configuration I wouldn't feel comortable pulling a trailer. I had hoped the temps would hover around 180 at 55 MPH with the fan disabled which would indicate that the thermostat is controlling the temp, not the fan.
My solution is to install and run the water pump fan during the summer months and remove it during the winter months. The single Spal fan application does a great job during the winter.
I hope this is helpful.
Since I made the above post I've had a chance to get more familiar with the electric fan. While I still wouldn't want to undertake pulling a heavy load very far on a hot day, the 2360 CFM Spal fan does a good job in Minnesota weather. From a practical standpoint I have to ask, how often is a bobbed deuce, or even a stock deuce, heavily loaded?
I had a parade yesterday in Virginia MN which is approx 45 miles from my residence. After the parade I drove over to Hibbing MN and then back home for a total trip of 130 miles. I should note that the trip included approx 45 minutes of stop and go parade driving.
The weather was in the low 70s and outside of when the truck was idling in the parade the fan never turned on once --- including when I crossed the continental divide in 5th gear at 2,500 RPM. It ran constantly @ 180 degrees which means that natural wind velocity @ 55 to 65 MPH on a low 70 degree day was suffucuent not to need the fan. I'm running a 180 degree thermostat.
My fuel mileage was a little over 10 MPG. Bear in mind that this is with an LDS engine and my foot buried in the pump.
It be fair I've been slowly turning the pump setting down (both the main and droop screw) a little bit at a time since my last post. I have yet to see a power drop as Rosie is still able to keep her hips in the wind in 5th-over.
No doubt the reduced fuel pump settings have relieved some of the workload from the fan
Having said all of this, If I were going to hook to my 18 foot McLander trailer and haul my M37 somewhere in the summer I would feel more comfortable installing the water pump fan for the trip.
The clutch fan mentioned previously would be a much better solution. I constantly worry that some kind of a malfunction will cause the fan not to come on when it is suppose to. It's all automatic but I still worry. I have a tattle-tail light on the dash that somes on when the fan is running.
At idle you can hear the fan which brings up another potential problem. I always make sure horses are not placed directly in front of me in parades. When the fan comes on with it's high pitch whine it spooks the horses.
